4x4 front calipers to a s2 erst
Old Oct 11, 2004 | 03:59 PM
rs220bhp's Avatar
rs220bhp
Default 4x4 front calipers to a s2 erst
how much work is it to fit them. will i need any special brackets or will they bolt straight on?
cheers steve
Old Oct 11, 2004 | 04:12 PM
Thrush's Avatar
Thrush
Irritating c........
Dont need any work doing to get 4x4 Cosworth calipers to fit S2 hubs - all you need is a 1mm spacer (commonly known as a washer ) on each bolt.
You also have to run 2WD Cso disc's, not 4x4 one's
Old Oct 11, 2004 | 04:27 PM
rs220bhp's Avatar
rs220bhp
cheers thrush. why cant you use 4x4 discs then?
Old Oct 11, 2004 | 05:05 PM
richm's Avatar
richm
the offset's wrong, 4x4 discs are a lot shallower than 2wd ones.
Old Oct 11, 2004 | 05:27 PM
Thrush's Avatar
Thrush
As rich said
2WD Sierra discs have the same offset as Escorts, but the 4x4 ones don't, and would mean the disc wouldn't sit in the caliper "jaws"
If you want a hand fitting them, here's a very good guide
http://users.turbosport.co.uk/cossie.../4x4fronts.htm
Old Oct 11, 2004 | 05:35 PM
rs220bhp's Avatar
rs220bhp
cheers guys
Old Oct 11, 2004 | 05:53 PM
BillyCabrio's Avatar
BillyCabrio
Will these fit behind 15" rims?
Old Oct 11, 2004 | 05:58 PM
Hardeep_Singh's Avatar
Hardeep_Singh
i've got this setup on mine and just like thrush said 1mm washer is needed.
Old Oct 11, 2004 | 05:59 PM
Hardeep_Singh
oops sorry yes they will fit under 15's mate
Old Oct 11, 2004 | 06:34 PM
Paul_RS's Avatar
Paul_RS
are these much better than the standard S2 brakes? Do they work well with the ABS?
Old Oct 11, 2004 | 06:41 PM
Hardeep_Singh
yep i thought they were better the standard setup and yes they do work well with the ABS but it works EVEN better with no ABS
Old Oct 11, 2004 | 07:05 PM
Paul_RS's Avatar
Paul_RS
was checking out the link that was posted up and apparantly the S2 callipers are better than the cossie ones 5% more powerful. I might go with one of his conversions using the S2 callipers. What you guys think?
Old Oct 11, 2004 | 10:36 PM
Thrush's Avatar
Thrush
I was going to post the same thing, but yes if you already have S2 calipers and not bought any 4x4 ones, I'd spend the £40 on the bracket set you need and use S2 calipers with 2WD discs, a) cos of the 5% more efficiency, and also you will retain your pedal feel as the calipers are matched to the servo (alledgedly, swapping to 4x4 calipers could result in a softer pedal feel)
Then you can also afford to spend another £40 on some decent braided lines too - muchos better than poxy rubber ones So spend £80 on brackets and lines, or spend £100+ on 4x4 calipers... Up to you, but both set ups are a good improvement on std set ups
jason_nike
Aug 18, 2019 10:53 AM
FlashRS
Sep 14, 2015 12:36 PM
C2 MAK
Aug 20, 2015 09:46 PM
2wdsaph ben
Aug 17, 2015 03:17 PM
Old ford
Jul 31, 2015 06:50 AM
