my mk2
Found the spec on ebay hope you dont mind me posting it??
:engine / gearbox
1750cc xflow
accrlight + 90 pistons.
300 hr race rally cam.
big valve port & polished head.
lightend & balenced flywheel.
uprated oilpump.
double valve springs.
brand new weber 45s with port matched inlet manifold with weber linkage.
modified distributor.
luminition electronic ignition.
magnicore ht leads .
omex rev limiter that has been set to 7000 rpm since build.
platinum plugs.
heavy duty coil .
3 core rad with electric fan.
burton alloy rocker cover.
rs2000 clutch and pressure plate .
ashley 4 branch manifold / exhaust system .
alloy fuel tank with facet fuel pump/regulator.
quaife straight cut 4 speed box with rosejointed quickshift with rs 2000 alloy bellhousing.
4:4 diferential.
:suspension/brakes
bilstein front and rear shocks.
heavy duty van rear single leaf springs on 3 inch lowering blocks.
front adjustible coilover coversion with 200 lb springs.
anti dive kit.
brand new 2.4 quick rack with rs2000 track rod ends.
poly bushes all round.
2.8 calipers with new vented cross drilled and grooved disks & new pads.
:shell
1300 gl.
brand new front panel .
brand new wings.
big transmission tunnel (accomadates heater).
steel quarter bumpers.
chassis leg to bulkhead gussets fitted.
rs mexico sticker kit.
:interior
rs turbo recaro seats
4 point sparco harneses.
saftey devices 6 point rollcage.
alloy fire wall.
alloy door cards .
alloy centre consol with powerkey (ect).
1600 clocks with rev counter .
omp steering wheel.
alloy pedals.
:wheels/tyres
13x7 superlights split rim lookalikes
:engine / gearbox
1750cc xflow
uprated oilpump.
platinum plugs.
heavy duty coil .
4:4 diferential.
:suspension/brakes
anti dive kit.
:shell
1300 gl.
brand new wings.
:interior
alloy fire wall.
alloy door cards .
omp steering wheel.
alloy pedals.
:wheels/tyres
Kiran1600E
11
Oct 2, 2015 11:35 AM
