RST Wont Always Start
Ive got a 1.8 zvh conversion on my RST, the problem i have is that it doesnt always start from cold. It bump starts no bother and it'll re start again if its any heat in it at all. This problem doesnt always happen, sometimes it will start when it is cold.
Anyone any ideas?
Anyone any ideas?
sounds liek the water temp sensor at the back of the inlet could be playing up and the ecu not getting the true reading, a spray with WD40 in the plug may solve it if its just a dry connection
in fact, this time of year etc, most plugs could do with a bit of wd40 or electriacal contact grease
also when did you last have a set of plugs, or even check the ones in it?
JK12
33
Apr 26, 2021 12:09 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
