lots for sale *look*
p8 ecu mapped by stu with closed loop + air injectors £?
motorsport leads 6months old £?
dizzy with 12 month old phase sensor, brand new cap and rotor £?
one of ryans looms 6months use for p8 with air injectors / closed loom with lambda sensor (not shown)
*prov sold*
an unfinished loom i was makeing for a mate that he decided he didnt want! just needs a few little bits finishing with extra plugs for amp/coil if your running coil pack overbraid and brand new plugs etc cost alot on their own!!
3 bar map sensor, same as other parts not used for long before the car came of the road so as new
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=180193715545
turbo dynamics md240 roller bearing turbo with the original reciept and the one for the new core when some shi* must of got it and fucke* it . . . £980! after that it was perfect for 5 months until taken off the road. has been kept clean etc. the same turbo as the reyland 3door used and is rated up tp about 460bhp with very low lag.to look at the ex housing is like a small turbo escos but its highly modified!
powdercoated bottom pulley for escos or 4x4 sapph with poly v belt
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=180193719459
autometer oil pressure + water temp guages with sensors
charge air temp guage
apexi avcr perfect without solonoid in black
late raven dash surround modified to fit guages
*prov sold*
JoeyBoyden
Jan 4, 2024 02:36 PM
jason_nike
Aug 18, 2019 10:53 AM
