ABS removal
I have not removed this before but from seeing it i would suggest using the pipework from a base Fiesta that has the two bias adjusters on the inner wing.
Use the pipework from this and then add the FRST non abs cylinder to the servo.
That will cost you nomore than Ł70 in total at a guess.
If you can wait till weekend i shall see if i kept my old pipework and parts your more than weclome to this for your set up...
I have a tendancy to throw stuff away, so dont count those chickens just yet.
I beleive at the rear of the car by the fuel tank these compnesators are located.. follow the pipework to it.
You will more than likely have to remove these too..
I think they are Fords equivalent to a Bias adjuster.
