ABS removal
Old 04-12-2007 | 01:08 PM
Rippers's Avatar
Rippers
Monte Geek
Default ABS removal
Anyone done this? any pointers please
Old 04-12-2007 | 01:49 PM
Luca's Avatar
Luca
Lukesville
I have not removed this before but from seeing it i would suggest using the pipework from a base Fiesta that has the two bias adjusters on the inner wing.
Use the pipework from this and then add the FRST non abs cylinder to the servo.
That will cost you nomore than £70 in total at a guess.
If you can wait till weekend i shall see if i kept my old pipework and parts your more than weclome to this for your set up...
I have a tendancy to throw stuff away, so dont count those chickens just yet.
Old 04-12-2007 | 01:51 PM
Rippers's Avatar
Rippers
Monte Geek
Cheers mate, I seem to remember reading something about someone having problems with the rear compensators? (what ever they ) are after removal?
Old 04-12-2007 | 02:31 PM
Luca's Avatar
Luca
Lukesville
I beleive at the rear of the car by the fuel tank these compnesators are located.. follow the pipework to it.
You will more than likely have to remove these too..
I think they are Fords equivalent to a Bias adjuster.
tankybaby66
06-02-2016 02:24 PM
muzzman1
30-09-2015 08:59 PM
Quick Reply: ABS removal
