DO ERST/FRST Starter Motors Suffer from Heat issues?
Mine is the 3rd RS I have had that does not like to turn over when hot.
I assume its to do with the starter motor.
Any one else suffer from this and is there a remedy?
hit it with a hammer
I think a heat shield will do the job just need to locate one.
Any one got a pic of one I will try and make one if not..
i had this problem years ago, i put a brand new ford, (std) starter on my car, drove 110 miles, stopped, it was dead,
left it a while,it started , as soon as i got home, i went to ford, and got a starter motor for a desiel , and its been 100% good, for a few years now, and it was a straight swap, as i moaned a bit .
knowing my luck, you will see a post tomorrow, " my car wont start" lol
the heatwrap sounds like a good idea though ,
and the hammer jim,
and the hammer jim,
Yep had this prob with all CVH engined Fords I've owned
My starter likes sapping all the power off my battery at the moment which is a pain in the arse
The early Zetec starters fit CVH engines I think, anyone confirm? Might go looking in the scrappy Tuesday
How much is the genuine Ford heat shield?
the way forwards is the ford heat sheild had this prob on one car fitted that heat sheild never had it since plus looks nice dont rap it never looks good plus timely and messey job when you can just clip the sheild on the oil return pipe trust me never again will you look like a plank out the clubs waiting for it to cool down
wes, i use a transit battery now, after i had probs with my std one, Ł70 approx from ford, but works a treat.even though i dont have any sterio system, not even a head unit, but the std battery still was a coont.
cheers Dave
cheers Dave
Seerhunter, my battery is a massive great thing, need it to drive the stereo! Fitting a power cap this weekend so hopefully that will stop all the power being drained by the 1100w amp and the starter when it sticks....
cossie09
Sep 10, 2015 06:56 PM
