revs up and down
hi
ive recently bought a frst and when the car is warm the revs go up and down and it looks like its going to stall. ive cleaned out the idle control valve and changed the plugs and leads. dont know what else to try?
regards gray
regards gray
have you cleaned the ISCV right?
http://www.fiestaturbo.com/forums/gu...iscv-vt155294/
also check the water temp sensor at the back of the inlet.
and as jon says, check for vac leaks.
is the car chipped?cammed, different air filter etc?
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
