Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Escort GTi pinking/flat spots
Old Dec 1, 2007 | 12:08 AM
Delvmatic's Avatar
Delvmatic
Default Escort GTi pinking/flat spots
Just a quick question because i am stupid
Having a wee bit of bother with the Escort GTi i have currently. Changed the Idle Speed Control Valve which has cured idling issues the car had, but i have noticed the car pinking and hitting dead spots basically and just no power when i give it a bit (seems to be about 4000 revs or thereabouts) The car as far as i know only has 1 mod and that's 2-litre cams rather than the standard 1.8 cams (although i do have the standard cams in the garage). Just wondering if the Air Flow meter in the car could be causing problems due to different cams and slight power increase. I was told to perhaps change to a 2-litre air flow meter and throttle body but i don't know if that'll help. Could the Air Flow Meter be faulty? Not sure how the air flow meter works with modifications to the car - would it have to be changed or removed at all?
Any ideas at all guys? Perhaps fuel pressure could be low also? Don't have time to get the car in anywhere this week so just looking for a few ideas first.
Cheers peoples
Old Dec 1, 2007 | 05:14 PM
Wardy257's Avatar
Wardy257
The ECU will be getting the wrong data from the MAF. The ECU and MAF need to match or you are stuffed.
Test this by disconecting the MAF and going for a spin.
Your ECU will also not know you have changed cams so will not be able to change igntion and fuelling. Get an RS1800 TB, MAF and ECU.
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
