Valves
Old Nov 29, 2007 | 09:54 PM
Billy_RS's Avatar
Billy_RS
Default Valves
Once you have taken valves out, is it ok to use them again?
Or do you need new ones?
Old Nov 29, 2007 | 09:55 PM
mechanic28's Avatar
mechanic28
valves can and should be used again if nothing wrong with them,just lap then in job done
Old Nov 29, 2007 | 09:58 PM
GARETH T's Avatar
GARETH T
yep use again
pugo's Avatar
pugo
dont forget to measure there length to see if they have stretched though
Old Nov 29, 2007 | 10:01 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
and shim accordingly
Billy_RS's Avatar
Billy_RS
Can you still buy the collets for them, i think i lost a few when stripping it down
Old Nov 29, 2007 | 10:07 PM
NEEDFORSPEED
yep youl be able to find some that fit alot are the same tbh
Old Nov 29, 2007 | 10:09 PM
Billy_RS's Avatar
Billy_RS
Anything else i should know before i go to bed?
Old Nov 29, 2007 | 10:11 PM
Red16's Avatar
Red16
if the valve faces are well pitted have them recut, save a load of time trying to lap them in.
Old Nov 29, 2007 | 10:16 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
if you snore,its normally a sign your over weight
Old Nov 29, 2007 | 10:20 PM
Billy_RS's Avatar
Billy_RS
I asked for that
Old Nov 29, 2007 | 10:34 PM
glancy2081's Avatar
glancy2081
if a valve had streached a would not be using it again
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
