Turbo fluttering noise?
Ive got a wierd problem that im sure the pf experts can solve.
Under heavy load, say pulling from lowish rpm in 4th, I can hear/feel the turbo almost fluttering/stuttering. I can also 'see' this on the boost guage, the needle shakes slightly.
Turbo is standard, wastegate is standard and set as it left the factory.
Any ideas?
Any ideas?
Originally Posted by Christian and Beccy
Originally Posted by Jonzy
Its not a ford
Could be something like the cat collapsed, causing the turbo to surge.
Could a standard turbo on essentially a standard engine actually surge?
Originally Posted by Daz-rst
could removing the cats from a 4x4 with a t34 cause the turbo to surge???
All the intake system on my engine is silicone/hard pipe so no standard rubber to collapse.
Surely a intercooler problem would show it self all the time, not just under heavy load.
I suppose the one answer is to stop being a lazy cunt and drop a gear
It could be that, labouring the engine, which is forcing the turbo to produce more boost before the engine has enough speed to consume the air.
Unusual for a standard car IMO, but not entirely inconceivable.
.63 and it was mapped with the cats and all i did was bash the insides out so their hollow tubes now
Daz - What are your symptoms? You sure you have 'Surge'?
As opposed to a boost spike?
Surge is usually along the lines of the turbo producing a volume of air before the engine is ready to consume it, hence why alot of BB turbo's surge. Removing an exhaust restriction is unlikely to produce surge IMO.
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
