Sapphire rear bumper removal
Old Nov 28, 2007 | 05:44 PM
bpspa's Avatar
bpspa
Default Sapphire rear bumper removal
I'm trying to remove the rear bumper on my 2wd sapphire cossie, I have found the plastic side clips but it still won't budge.
Are there any other bolts or clips that I need to remove and where abouts are they?
Ben
Old Nov 28, 2007 | 06:02 PM
broos3's Avatar
broos3
From: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
I take it you have turned the two plastic clips through 90 degrees? The ones behind the wheel arch liners on the bumper?
There are also two torx bolts that secure the bumper frame to the bottom of the floor pan. These are located under the boot carpet, one on each side infront of the rear lights.
Bruce
Old Nov 28, 2007 | 08:38 PM
Yeh there are two 40 torx bits on the boot floor. I bet they are seized i had to drill mine out. I was fitting a new bumper cause my old 1 was cracked. If your fitting your bumper back on you will have to drill and retap the threads on the bumper brackets.
Old Nov 29, 2007 | 07:16 AM
bpspa's Avatar
bpspa
Bruce
Yep turned the plastic clips and got them off, just didn't see the torx bolts. Will have another look tonight, do I need to remove the rear lights to see the bolts?
Old Nov 29, 2007 | 09:26 AM
broos3's Avatar
broos3
Bruce
As glen said above we think they a size 40 torx bits. No you dont have to remove the rear lights, the bolts are on the boot floor and fairly easy to spot after the carpet is up.
When the bolts are out, then slide the bumper off the rear of the car. If its abit sticky be patient and even spray some wd40 on the plastic sliders near the plastic clips you turned.
Bruce
Oct 9, 2015 07:38 PM
Aug 29, 2015 08:16 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
