AP's on a 2wd
Old Nov 28, 2007 | 04:05 PM
Reece's Avatar
Reece
Default AP's on a 2wd
hi i have just put Ap's on the front of my 2wd saph.
ive had to put spacers on to keep them away from the wheel. has any 1 else done this and wot size did you go for?
also as i turn the disk catches the calliper has any 1 had this and any ideas how to sort this??
any advice will be a big help thanks again
Old Nov 28, 2007 | 04:08 PM
Dan's Avatar
Dan
I expect it's the wheels if your on 17'' Diamond cuts mate and not the brakes!
AP's are notorious for fitting perfectly and Diamond cuts are notorious for having crap clearance on brakes!
Old Nov 28, 2007 | 04:41 PM
Niall.b's Avatar
Niall.b
cant really say but i used a selection of very fine shims & spaced the caliper mount bkt out until it was perfectly central to the disc. have seen the caliper having to be radially spaced to prevent the disc rubbing on the inside of the caliper when driven hard & it heated up
Old Nov 28, 2007 | 05:50 PM
Reece's Avatar
Reece
the wheels are no longer catchin ive sorted that. the disk is catchin on the outside of the calliper.
its as though it needs to be further out i.e takein some off of the inside of the bracket
Old Nov 29, 2007 | 09:50 PM
col cos1's Avatar
col cos1
is the fitting brackets from ap or ggr?
i had to take 3mm off the ggr brackets to get the disc and pad to sit correctly
Old Nov 30, 2007 | 03:53 PM
Reece's Avatar
Reece
there from ap thats why i cant understand it
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
arfurski
Sep 26, 2015 10:39 AM
Russ Payne
Sep 25, 2015 08:29 PM
dojj
28
Sep 11, 2015 10:00 PM
