working out speed from gear ratio, diff standard 2wd
Old Nov 27, 2007 | 09:54 PM
scoooby slayer's Avatar
scoooby slayer
Default working out speed from gear ratio, diff standard 2wd
hi i dont know if anyone can help ive got a formula i use to work out speed from gear ratio, diff ratio and wheel revs.
i work it out like this 8000 rpm x 60 = 480000
wheel revolutions a minute 897, diff ratio 3.64, 5th gear .80.
so 897 x 3.64 x .80 = 2612.064
480000 / 2612.064 = 183.7 at 8k in fifth standard wheels.
but i have it on good authority that with 17s and 40mm tyres actual speed is 195 ish.
so i tried to work out wheel revolution a mile by calculating circumference of larger wheels and it works out at 165 mph
now the only thing i didnt check for myself in the above equation is the wheel revs which i was told is 897 per mile on standard wheels.
does anyone know what im doing wrong
Old Nov 27, 2007 | 09:57 PM
rapidcossie's Avatar
rapidcossie
most folks use this calculator...
http://www.gearboxman.co.uk/inforatios.html
scoooby slayer
also apparently ford state 149 mph at 6500k revs so can i do this.
149 mph divided by 6500rpm then x 8000rpm = 183.3 mph ay 8k
Old Nov 27, 2007 | 10:01 PM
rapidcossie
its rolling radius of the wheel that make all the differance mate.
Old Nov 27, 2007 | 10:08 PM
rapidcossie
i work out to 200 mph in 5th at 8k using a 0.8 final 5th and 3.64 final drive on 235 40 17 tyres.
Not 100% sure that is correct for a 2wd final drive tho
Old Nov 27, 2007 | 10:26 PM
scoooby slayer
ford workshop manual states 3.64 diff. when you have 215 tyres front and 235 tyres rear which size do you use for calculation ?
rapidcossie
rear tyres as its rear drive
Old Nov 27, 2007 | 10:29 PM
scoooby slayer
Old Nov 28, 2007 | 12:16 AM
scoooby slayer
thanks euan
Old Nov 28, 2007 | 07:13 AM
dojj's Avatar
dojj
Resident Wrestling Legend
don't forget that this is a purely basic ratio calculation and it doesn't take ito account tyre swelling the faster you go which can account for an extra bit of speed
the maclaren F1 was geared to hit the limiter at 225 mph but their first run out saw it doing 231, so there was some serious head screatching going on there, because you aren't supposed to be making that sort of mistake when you build a car that expensive
Old Nov 28, 2007 | 08:50 AM
scoooby slayer
it is strange my car was mapped to hit the limiter at 7800 rpm which according to the calculator is 156. but my speedo shows just over 140 hitting limiter in 4th although i know the speedo is under reading a bit but no more than 5 mph so ? i thought my speed was around 145 unless my limiter is a bit lower for some reason cant tell as rev clock only goes to 7k
Old Nov 28, 2007 | 09:12 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
What size tyres are you running?
Old Nov 28, 2007 | 09:19 AM
TiB's Avatar
TiB
Measure your tyre again in mm's.
Then divide... 1 609 344 millimeters x the number of mm's your tyre measures. (my guess is it'll be around 820) thats your revolutions per mile.
Then do your equation again like you did at the top of this page
ps.. its revolutions per MILE not per MINUTE
Old Nov 28, 2007 | 09:21 AM
TiB's Avatar
TiB
Also... if you limiter is set too 7800 i would guess you have a soft cut limiter around 7600 which you will prob only feel in 5th.
Old Nov 28, 2007 | 12:25 PM
scoooby slayer
not sure on that mate stu said he was doing 8k limiter and soft limiter at 7.8k but on the mapping paperwork just says limiter set to 7800 rpm
Old Nov 28, 2007 | 12:31 PM
scoooby slayer
i meant mile
im confused by the equation above ? 17 in rims and 235 40 tyres. can you show me the equation for working that into revolutions per mile please mate ?
nice 3 door to its
Old Nov 28, 2007 | 12:32 PM
scoooby slayer
17 inch rims, 235 40 tyres.
Old Nov 28, 2007 | 12:40 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you will never be totally accurate unless you accurately measure the actual diameter or better still circumference of your tyre as it deforms and goes along. using standard tyre measurements will not be accurate as there can be a big difference between new and worn tyres, tyre pressure etc
Old Nov 28, 2007 | 01:02 PM
Mike Rainbird
Caraholic
As a rough guestimate (going by a fixed* tyre circumference of 1947mm for a 235/40x17):
7800rpm = 194.45mph on 0.80 fifth gear and 3.64 final drive.
7700rpm = 191.96
7600rpm = 189.46
7500rpm = 186.97
7400rpm = 184.48
7300rpm = 181.98
7200rpm = 179.49
7100rpm = 177.00
7000rpm = 174.51
*due to centrifugal force, the diameter actually grows slightly, so you may achieve fractionally higher speeds than quoted, or as Nick points out, the above circumference is based on a new tyre and an almost fully worn item could be up to 1.5% less speed.
Old Nov 28, 2007 | 03:16 PM
scoooby slayer
7700rpm = 191.96
7600rpm = 189.46
7500rpm = 186.97
7400rpm = 184.48
7300rpm = 181.98
7200rpm = 179.49
7100rpm = 177.00
7000rpm = 174.51
thanks mike
Old Nov 28, 2007 | 03:20 PM
scoooby slayer
spoke to kenny at msd today 7800 is soft limiter and 8000 is limiter
maybe i am doing 150 on the limiter in 4th
cant check it with sat nav as id have to hold it on the limiter for a few seconds and i dont wana do that else il be
Caddyshack
15
Aug 4, 2015 08:50 AM
