At last
Finally back on the road with my new 1660cc low comp bottom end and a new turbo.
Only new snag is that the alternator blades has slit me bottom hose pipe
But at least ahe running sweet again now
adam bored out to 1660cc, oversize pistons skimmed, lightened balanced knife cut crank!!!!
Dave-found the reason. I forgot to put a bolt in the rad
It must have moved and caused the pipe to catch the alternator
