Fiesta Zetec S ABS Problem
The ABS / Traction control light won't go out on my W reg Fiesta Zetec S. Took it to my local garage on Saturday who have told me it needs 2 new front ABS sensors at £110 each
Have checked the sensors today and can't see an obvious damage to them and have also check the connecting plugs to make sure they are not corroded but all looks good.
Seems odd to me that both sensors would go at the same time, has anyone else had this problem or know of any other common faults which could cause the ABS light to come on?
just seen this thread
but no wont be both sensors sounds like garage was just taking a guess and covering themselfs.
I replace the ABS sensor on our ZS, i tried one side and it still had the light on, so swapped it to the other side and fixed it
but no wont be both sensors sounds like garage was just taking a guess and covering themselfs.I replace the ABS sensor on our ZS, i tried one side and it still had the light on, so swapped it to the other side and fixed it
JoeyBoyden
Jan 4, 2024 02:36 PM
