Ford mondeo Query
Old Nov 26, 2007 | 04:15 PM
serious 1's Avatar
serious 1
Default Ford mondeo Query
My dAd has just given his car into a local garge to fix his handbrake,and they fitted a offside rear brake caliper,rear discs and pads and 2 new front pads,the travel on the hand brake handle is now better but there is hardly any braking there at all at the mo,the technician said that this is normal and will work fine after 90miles or so,does anyone know if this will be the case?
Old Nov 26, 2007 | 04:35 PM
serious 1's Avatar
serious 1
Just to add it is on a 02 plate and he said that will just need bedding in,I know brakes need bedding in,but i didnt think that would effect the sharpness of the handbrake itself???
Old Nov 26, 2007 | 04:40 PM
dojj's Avatar
dojj
Resident Wrestling Legend
ford did a recall on the handbrake on 02 mondeo's
they reroute the cable as it sticks sometimes and there is a change of the adjustment system as some have self adjusting and some don't
call ford and see if it was recalled or not
Old Nov 26, 2007 | 05:17 PM
serious 1's Avatar
serious 1
I have just spoken to ford and unfortanatly no recall on this car.
Old Nov 26, 2007 | 05:44 PM
ECOS95's Avatar
ECOS95
The new brakes will take a while to bed in which is probably what the mechanic meant. Can't see why that wouldn't also be the case for the Handbrake.
Old Nov 26, 2007 | 05:59 PM
serious 1's Avatar
serious 1
Do you know how long this normally takes?
Old Nov 26, 2007 | 06:01 PM
filthyrichie's Avatar
filthyrichie
tottally correct it will be fine 50 -100 miles all will be well
borboyous
Aug 22, 2015 11:17 AM
