Alarm problems
Old Nov 25, 2007 | 10:52 PM
cossieracer's Avatar
cossieracer
Default Alarm problems
A couple of weeks ago my cossie gave up the ghost or should I say it refused to go. Off it went to interpro and £623.00 later was "fixed" apparently too many alarm systems on it and one proved faulty and therefore removed car returned. Got in it today and yes exactly the same, engine turning over but no fuel going through. Any suggestions, I cant afford to give interpro another £623 again two weeks later with the same problem?? can anyone help????
Old Nov 25, 2007 | 11:00 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
how much! i could have removed all the old stuff and fitted a new shiney cat1 with window closure for way less than that.....and they havent even fixed it...go and give em hell!
Old Nov 25, 2007 | 11:09 PM
pani_k's Avatar
pani_k
PassionFORD Member
couldve had a clifford 650 with plenty of options for that!!!!
and all they did was remove a few wires and a couple of boxes
charlie luciano's Avatar
charlie luciano
Nothing to do with the fuel cut off switch in the boot is it?
Luciano
Old Nov 25, 2007 | 11:12 PM
cossieracer
Is there any other reason that it would display the same symptoms, does anyone know? I am sure that if I phone interpro they will treat it as a completely new issue, although I am sure it is not. Could really do with some advice??
Old Nov 25, 2007 | 11:14 PM
cossieracer
my cut off switch is in the front passenger side
Old Nov 25, 2007 | 11:16 PM
JTECH James
Passion for Fords!
could be soooo many things.first off you want to find out what isnt working,fuel pump?spark?and then trace it back from there
Old Nov 25, 2007 | 11:20 PM
T28 RST's Avatar
T28 RST
Ok then
£623
Thats more than most alarms cost never mind just getting one repaired
Old Nov 25, 2007 | 11:21 PM
cossieracer
one thing yesterday when I drove it everytime I put my foot on the accelerator it didnt pick up on power (thought it was cause I had my wellies on and a stinking cold)
Old Nov 25, 2007 | 11:22 PM
JTECH James
Passion for Fords!
or not in this case
Old Nov 25, 2007 | 11:38 PM
SS1's Avatar
SS1
what cars that ..on my 4*4 k reg its in the drivers foot well
its behind the right hand side plastic bit
Old Nov 25, 2007 | 11:52 PM
cossieracer
It an M reg Escort cossie. its in the front passenger foot well on the left hand side. When that pops does the engine still try to turn over or does it just do nothing like its dead??
Old Nov 26, 2007 | 12:04 AM
SS1's Avatar
SS1
ah sozz..you never stated the car in the first post
if it pops out it just cuts the fuel pump supply..the engine should still turn over just no petrol via the pump
Old Nov 26, 2007 | 12:12 AM
cossieracer
oops I shall have a look in the morning .Fingers crossed cause I cant afford another £623 or have them come up with "a new issue"! can't help but think that they are really taking me for a ride afterall they can say anything and who am I to argue!! This is when I hate being female
Old Nov 26, 2007 | 12:19 AM
SS1's Avatar
SS1
go back and complain take somebody with you whos in the know..or a fair idea car wise..tbh without all the facts or pictures..i think your getting ripped off BIG TIME
good luck
Old Nov 26, 2007 | 12:31 AM
cossieracer
you and me both and thank you L8 ECU used to be a good friend sadly lost touch
Old Nov 26, 2007 | 12:43 AM
glancy2081's Avatar
glancy2081
fuse box
Old Nov 26, 2007 | 01:15 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
interpro are known to be fookin robbers
Old Nov 26, 2007 | 03:35 AM
mrjenrst's Avatar
mrjenrst
Sorry but nothing to do with been a bird!
623 does the cunt sit outside with a dog and a shotgun for that?
As above you can get all alarm's removed and a concept 650 fitted for that. And it's the shit.
Go back and shout at the dick turpin wannabe.
Old Nov 26, 2007 | 07:03 PM
cossieracer
Phoned interpro today at 12.30, blurted out the fact that after parting with £623 and two weeks later car still with same problem as before parting with money ie it wont go, I am still waiting for them to call me back. I am so frustrated and dont know where to turn
Old Nov 26, 2007 | 07:24 PM
Dave Parker's Avatar
Dave Parker
Originally Posted by glancy2081
fuse box
probably
Old Nov 26, 2007 | 07:31 PM
cossieracer
fuse box
probably
Elaborate a little please
Old Nov 26, 2007 | 07:50 PM
Dave Henshall's Avatar
Dave Henshall
a fuse box is anojther couple of 100 £ that again if wrongly diagnosed is a wastre of money, more thab likely cruddy wiring, my esocs had 2 alarms and 2 imobilsers on it when i got it......reet fookin mess, AND needed a fusebox, ignition switch and some duff sensors replacing
it was like a the coonin factor to get it started with all the fobs, keys and plug ins...!!
check out its 2 day haircut..... total cost for alarm rip out and reinstall of toad cat 1, £250.
fusebox £230
sensors, £75
Old Nov 26, 2007 | 08:01 PM
cossieracer
I had three alarms and imobilisers, they removed the one they said was causeing the problem, it worked for 2 weeks and then back to square one. It is seriously doing my head in. I live in the middle of nowhere and no wheels
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
