GT30 peeps
Fitted the turbo today after lobing off the old mounting for the turbo damper and the outlet of the comp housing is very close to the alternator.
My question is this... What have you done for your boost pipes and i take it i need a drop bracket for the alternator and where is the best place to get one
Any pics would be good
Thanks
Thanks
yes mate thats the one
when you fit it you will have to cut the lug off on your block to get it to fit, this will make sense when your alternator and bracket is off
i will say i didnt use standard belts purely as the standard ones didnt really fit with out modding the arm bit.
O well if needs must
Yes have been looking @ these.
This one i take it http://cgi.ebay.co.uk/Cosworth-76mm-...QQcmdZViewItem
Thanks
Thanks
i made up a longer top bracket to allow the alternator to drop down as much as possinle. belts are 1 metre long and allow the boost pipe to run over the top of it (with the rs500 drop bkt too)
Good idea mate
Originally Posted by -==chunk==-
when i got my pipes made i said to roose i have a gt30 to radtec 500 cooler and they already knew the size
What the guys name so i no what to call him when i send him a email
Chris Rogan @ motorspares. took a bit of messin around. the belts come in 5mm incriments so u can get it pretty close depending on how much adjustment u have on the top arm. i made mine the exact fit & had to redrill holes when i put the alloy waterpump pully on. will have to do the same again i think as i now have the ally power steering, crank & alternator ones to match (along with a lot more goodies) as its that time of year
im using 1 x 044 bosch pump & 4 x 1000 cc injectors. talked this through with Mark Shead & is as he recommended. have aeromotive pressure regulator as opposed to standard
paceo
Sep 25, 2015 08:05 PM
paceo
Sep 17, 2015 12:12 PM
