Rear Lights
Old Nov 23, 2007 | 10:56 AM
Daveesaunders's Avatar
Daveesaunders
Default Rear Lights
Damn things have gone tempremental and wokr when they feel like
Going to cut the plug off and put some female spades on. Another job for this afternoon as if I didn't have anything better to do
Old Nov 23, 2007 | 06:11 PM
I would check the connections and make sure they arnt all corroded. Ive had 2 sierras now 1 hatch back n a cossie and ive cleaned off the corrosion on both of them. It souldnt be that hard to cut the connections off and put new spade connectors on.
Old Nov 23, 2007 | 07:31 PM
The best long term bet is to solder them to the loom, just scrape off the galvanising on the tracks and solder with silver solder.
If you put a 1N5408 DIODE(about 7p) between the brake lite and fog wire you get the fogs to light up with the brake lights but still work as fogs on thier own, MOT freindly and legal, makes a hell of a difference, if you don't want the rear fog light switch to light each time you brake insert another in the feed from front to rear.
Old Nov 24, 2007 | 11:23 AM
xr4man's Avatar
xr4man
sounds like you just need to clen the connector and add in another ground wire.
Old Nov 24, 2007 | 05:24 PM
Tabetha thats what my old sierra used to do. The fog light warning light on the switched used to do.flicker on when use brake was pressed.
Old Nov 24, 2007 | 08:31 PM
xr4man's Avatar
xr4man
yeah that sounds just like the common problem we have with our merkurs. we just clean the connector and add a ground wire from the "circuit board" on the tail light to the body somewhere. 99% of the time that takes care of the flashing tail lights.
Old Nov 25, 2007 | 11:48 AM
CosKev3's Avatar
CosKev3
As above.damp/wet in the connection plug could be the board itself is fooked though
Originally Posted by tabetha
If you put a 1N5408 DIODE(about 7p) tabetha
Nice info
Best place to get them from please??????
Old Nov 25, 2007 | 01:15 PM
Maplin's for these as cheap easy ready to go.
You can use any 1N4000 series RECTIFIER DIODES, but 1N5408 is a much heavier duty version of them.
I do this brake lite/fog lite mod on all my cars, with these diodes, the difference in people backing off when you brake and then NOT sitting up your rear is worth it for this alone!!
Adding an earth(seperate) is a good idea, but ONLY stops other circuits drawing through unused/unlit bulbs and does not solve the problem of the crap design that is the cause.
I usually just drill a 3mm hole in each track insert tinned wire and solder, job done permanently, but up to you.
Old Nov 26, 2007 | 02:18 AM
SS1's Avatar
SS1
nice tip cheers
Old Nov 26, 2007 | 07:02 PM
Miller 3's Avatar
Miller 3
tabetha Strikes again
Well done mate
Old Nov 27, 2007 | 06:22 AM
This seriously needs doing on any cos as it is so cheap and amazing effect, only ever been stopped once, showed copper that I still had normal brake light when fogs were switched on so no offence, MOT friendly too.
I also use HALOGEN bulbs in the rear of the car from goffy.
Bailes1992
Sep 3, 2015 02:17 PM
mint_s2
Sep 2, 2015 08:58 AM
RsS2daz
Aug 14, 2015 05:26 AM
sridgett
15
Aug 3, 2015 07:26 PM
