Best way to route gauge wires/pipes?
Old Nov 21, 2007 | 10:12 PM
Paul_RS's Avatar
Paul_RS
Default Best way to route gauge wires/pipes?
Whats the best way to run boost gauge and oil temp/pressure wires from the engine bay on a sapphire?
I'd prefer not to drill any holes if possible!
Thanks!
Old Nov 22, 2007 | 09:54 AM
iansoutham's Avatar
iansoutham
OCD Victim
There is a big loom grommet on the passenger side of the engine bay quite low down. There should be a spare insert or 2 in there you can use. Comes out right by the ECUs behind the glovebox.
Old Nov 22, 2007 | 11:34 AM
JamesH's Avatar
JamesH
As above, or if going in a pillar pod, You can run them along the top of the bulkhead with the washer jet pipes, then through a gromet on the drivers side and take the speedo clocks out and they can just go straight upto the pillar pod
Old Nov 22, 2007 | 05:43 PM
Paul_RS's Avatar
Paul_RS
Thats great guys, cheers!
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
