mk1 fiesta rst turbo conversion
hey everyone am after so help and advice i am converting a mk1 fiesta 1.1 too run series 2 rst engine have done it too a mk2 xr2 so now about how too get engine running but unsure on items lie engine and gearbox mounts etc a little help please
Hello mate .i am in the process of finishing my mk1 frst,what do ya wanna know?
You will need to convert the n/s chassis to fit the escort box as it is too long,you can use a mk1 xr2 engine craddle and i am using vibra tecnics mounts,and the same as the mk2 you will have to cut the front cross member to make way for the down pipe, i also cut the centre of my front valence out to fit a frst rad if thats the route you wanna take and i had an intercooler made to fit the rest of the hole left in the front panel.
hope this helps
mark.
hope this helps
mark.
hay mark or any1 that can help,am doing the same conversion,everything is done apart from my gearbox mounts wont line up with the engine craddle??why is that? i have a s2 box and engine,the mounts on the box seems as its to far over to pasnger side,have i got the rite box? or what is it a missing? it would be great help if yous can help,thanks,
jamie
jamie
Sign up to http://xrtwo.speedcentral.co.uk/ and have a look on there. Been done loads and loads of times with all incarnations in between.
Billy_RS
16
Oct 11, 2025 09:41 PM
Matt Baxter
Sep 16, 2015 08:30 PM
