Sapphire Petrol Tank & Straps & fuel cradle
Old Nov 21, 2007 | 02:57 PM
silky16v's Avatar
silky16v
Get on That!
Default Sapphire Petrol Tank & Straps & fuel cradle
right gonna replace the tank & straps
wheres best to get these new i know you can get after markets tanks but what about the tank straps?
also need a replacement cradle does some1 do a replacement for these?
or is it try do the best with the 1 i've got
Old Nov 21, 2007 | 03:15 PM
fordsportjay's Avatar
fordsportjay
ive got 1 brand new tank strap knocking about...
Old Nov 21, 2007 | 10:50 PM
CosKev3's Avatar
CosKev3
Pattern part tanks are around £50 delivered,Ford tank £200
Try :
http://www.shopcreator.com/mall/depa...05/1/1/-/75905
Sure its a F60C tank you want,but better check that
Pump cradles go for silly money new on E-Bay,never priced them at Ford
Old Nov 21, 2007 | 11:09 PM
Paul_RS's Avatar
Paul_RS
You can still buy the cradle from ford, think its around £50 but don't hold me to that!
Old Nov 22, 2007 | 08:41 AM
fordsportjay
ive got a brand new ford pump cradle too!
Old Nov 22, 2007 | 10:11 AM
jon@work's Avatar
jon@work
Get down to your nearest Ford dealer and get some new captive nut clips:
3 off finis number 6767592 at about £1 each
Allow yourself plenty of time to get the old tank off - the old fixings will annoy you.
Old Nov 22, 2007 | 11:32 AM
JamesH's Avatar
JamesH
Don't get a tank strap from auto specialists - mine didn't fit... thanks a bunch
Old Nov 22, 2007 | 12:09 PM
silky16v's Avatar
silky16v
Get on That!
thanks for that i've found a new cradle just not the clamps that hold the filter & pump in place though.
will check condition of my tank when i remove it before purchasing owt new
Old Nov 23, 2007 | 11:29 AM
PAUL S's Avatar
PAUL S
look through the sender hole in the top of any pattern tanks as some cheap ones dont have the swirl pot inside, and this causes problems
Tricky Dicky on the RSOC sells the correct ones
Straps are still available from Ford
Old Nov 23, 2007 | 01:09 PM
the saint's Avatar
the saint
i got mine from tricky dicky and i got the strap from him too
Old Nov 23, 2007 | 04:50 PM
matt4's Avatar
matt4
are all 4x4's the same? where is it best to buy a tank and all the necessary things from? my actual tank is leaking but i dont know which bits i may need (other than the tank itself0
where is the best place to purchase most parts from
Old Nov 24, 2007 | 09:42 PM
charlie luciano's Avatar
charlie luciano
The tank rusts and then leaks on the joining seams, top half/bottom half, all fuel tank bits should be still available, I got new tank from ford at iirc £190, strap around £10-15 and pump cradle is about £90
Luciano
Old Nov 25, 2007 | 09:41 PM
matt4's Avatar
matt4
Luciano
is there a cheaper option for this one for a 4x4 ford cosworth? maybe a reproduction item and not original ford one that splits
thank you
JK12
33
Apr 26, 2021 12:09 PM
Kam B
Sep 24, 2015 10:40 AM
atm
Sep 7, 2015 05:39 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
