Cossie heated front windscreen
Old Nov 20, 2007 | 06:49 PM
Default Cossie heated front windscreen
Hi there people since ive had my cossie the front heated windscreen has never worked. The light on the button lights up but nothing seems 2 happen. Is there anything common 2 look for. Also i noticed tonight inside the car seemed to be well steamed up inside. It was raining outside though. My carpets arnt wet. Any help would be gratefull.
Old Nov 20, 2007 | 06:51 PM
KSA-Cossie's Avatar
KSA-Cossie
Probs the power relay behind the glovebox m8.
Old Nov 20, 2007 | 07:16 PM
mechanic28's Avatar
mechanic28
for the steaming up bit make sure the rear airflow ducts are not blocked take it that she is a sapp
Old Nov 20, 2007 | 07:19 PM
Yeh its a saff 4x4. So the heated screen relay is near the glovebox next to the ecu relay and the fuel pump relay. Where are these rear ducts at then. The heaters are lovely and warm but the hole car was steamed up.
Old Nov 20, 2007 | 07:28 PM
mechanic28's Avatar
mechanic28
in the boot lift up the carpets at each corner behind the rear arches u will see some plastic vents make sure they r all clear
Old Nov 20, 2007 | 08:22 PM
Or right sweet are they inside the boot where the bumper comes round. If you know what i mean.
Old Nov 20, 2007 | 10:19 PM
mechanic28's Avatar
mechanic28
yep
Old Nov 21, 2007 | 06:44 AM
Sweet i will have a look. How do they block up anyway.
Old Nov 21, 2007 | 06:48 AM
So the relay for the heated front windscreen,is it in the passenger side foot well and is it clipped onto the bottom of the dash with the other relays. What color are they?are they purple by any chance.
Old Nov 21, 2007 | 07:20 AM
KSA-Cossie's Avatar
KSA-Cossie
On my facelift saph they're on a seperate wee sub loom m8 behind the glovebox under where the ecu sits.
Old Nov 22, 2007 | 06:57 AM
Or right thanks i will have to have a look. Do you know what color the relay is so that i know what im looking for.
Old Nov 22, 2007 | 06:01 PM
KSA-Cossie's Avatar
KSA-Cossie
Both black iirc.
Old Nov 22, 2007 | 06:36 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
check the screen hasnt been replaced with a non heated one..... if you look at it close up you can see the elements running top to bottom,and following that check the wire connections in both bottom corners of the screen,
Oct 9, 2015 07:38 PM
borboyous
Aug 22, 2015 11:17 AM
C2 MAK
Aug 20, 2015 09:46 PM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
