Got myself an Escort problem. (Idle Control Valve)
Hi
I work for Greenlight and currently have a modified 1998 1.8 Ford Escort si (1st car
) Which im having problems with and just need some help and advice on making sure that im buying the correct part for my car, I need an idle control valve, I think i have found one off of Ebay but i want to know if its going to fit, So i thought ill ask the pro's
Ebay link to the part:
http://cgi.ebay.co.uk/Ford-Fiesta-Es...QQcmdZViewItem
Thanks Dave
Thanks Dave
Hi Dave, that doens look like an escort one to me, they look more like this
http://cgi.ebay.co.uk/IDLE-SPEED-CON...QQcmdZViewItem
they are situated on the rear of the inlet manifold, quite easy to get to so IMO i would remove it and have a look before parting with any cash
i have an escort one at home somewhere, if i can find it ill get some pics of it for you
you happen to know if there is any guide to removing the part?
As Dan said, its not too bad.
I would recommend taking yours off, cleaning it with carb cleaner, and then working the valve/spring loose and see if this cures if. if it does you can be sure a new ISCV will fix it.
Beware as most of the ones off eBay don't work
i replaced mine with a new one from fords twice and the problem did not go away
so now running around with it disconnected and apart from stalling once or twice when cold runs fine when warm
think i'll just sell the car
Check the breather pipes before buying a new iscv unit as a split breather pipe WILL give same effect.
Dont forget the pipe underneath towards the back on the escort (The one you cant see normally)
I changed mine, its pretty easy stuff, get ready tho cause you will cut you hand on somthing
Mine still ran crap after, so reset ecu (disconnect battery for a few hours) and its been spot on since
How did you get to the valve, did you use a jack?
I have done an ECU reset which seems to helped a little bit, Ill check for airleads as suggested and if nothing has change ill try taking the valve off and try to clean it
