Sierra Polyurethane transmission donut.........
Old Oct 9, 2004 | 08:28 AM
Graceland's Avatar
Graceland
Team HOTHOT!
Default Sierra Polyurethane transmission donut.........
anyone have problems with these disentegrating under heavy load? found this which may cure some of the problems.....
http://www.opmd.com/main.cfm?tpl=product.cfm&pid=833
Old Oct 9, 2004 | 08:34 AM
Rene's Avatar
Rene
is that the one that goes ontop of the box?
Old Oct 9, 2004 | 08:44 AM
Graceland's Avatar
Graceland
Team HOTHOT!
goes on the tailshaft of the box between the propshaft flange and output flange - defo on the 4x4 box, not to sure about the 2wd tho
Old Oct 9, 2004 | 02:55 PM
xr4x4rs's Avatar
xr4x4rs
thats for a normal sierra and garnada prop not xr4x4 or 4x4 cosworth
the xr/cosworth has a bearing in the middle which locates the the centre of the prop and the gearbox
i fitted one of these as in the pic but a rubber one got a very bad vibration at speed and then had major problems when tried to drive through it it snapped the end o f my gearbox off
these are not for 4x4 cosworth trust me not to shore on 2wd
Old Oct 9, 2004 | 03:41 PM
Graceland's Avatar
Graceland
Team HOTHOT!
well why do they come as standard (but in rubber, usually coupled with a little flywheel thing aswell) on ALL sierras post 1987 then.................
Old Oct 9, 2004 | 05:03 PM
DazC's Avatar
DazC
It looks pretty similar to the Escort Cossie one but it's not quite the same. It's Deffo not the same as a Sapphire 4x4 one as that has a bearing in the centre....
Old Oct 9, 2004 | 11:50 PM
Fastmaul's Avatar
Fastmaul
K155MYRS
hey, that's my good friend Phil(OPMD!)
That's for the XR, i didn't the cossie's used them??
Old Oct 9, 2004 | 11:56 PM
FletchCossie's Avatar
FletchCossie
My Esc Cos one looks a bit worn... Is there an uprated one available? If so, is it any good or does it cause vibrations, etc??? Do they sell them seperately at Ford's??
Old Oct 10, 2004 | 12:19 AM
xr4x4rs's Avatar
xr4x4rs
the xr4xr 2.9 and 2.0 models use a fat rubber donught with a bearing in the middle the same as a sapphire 4wd cosworth
the 2wd cosworth uses the same or similar as in the pic (no bearing) and then another part of the prop bolts to this then slides into gearbox
the escort cosworth uses the same style as a 4wd sapphire cosworth and xr but it is slimmer and stronger. (its only slimmer because the escort gearbox has a longer input shaft than a sapphire so i was told? )
the donghts i have explained are correct in these models as i have had so many problems with mine
Old Oct 10, 2004 | 12:24 AM
djskitzy's Avatar
djskitzy
I was gonna put summat like wot xr4x4rs wrote, but he's wrote it, so just read that again, cos he's right.
What do you drive xr4x4rs? have I seen you at the alvis?
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
