Esc Cos Fuel Rail Removal
Old Oct 9, 2004 | 08:27 AM
bigrs's Avatar
bigrs
Default Esc Cos Fuel Rail Removal
Has anybody out there tried to remove their fuel rail?
How do you get the two fuel lines off at the rail end?
Dont really want to cut them off!!
Old Oct 9, 2004 | 08:42 AM
cossymad's Avatar
cossymad
Pull them f*cking hard!!!!!! They are very tight!!!
Old Oct 9, 2004 | 08:47 AM
bigrs's Avatar
bigrs
Will have another go later. They are twin coated and when I pull the outer rubber line seems to stretch, its the inner line thats plastic thats a bi**h!
Old Oct 9, 2004 | 02:33 PM
THE RADMAN's Avatar
THE RADMAN
i shouldnt try and remove them as youll end up snapping the plastic fuel line,if you do manage to get it off it wont seal again properly
Old Oct 9, 2004 | 06:22 PM
bigrs's Avatar
bigrs
My thoughts aswell. If the plastic inner pipe runs all the way through the outer pipe then maybe cutting it could be an option, as when installed again it will be a fresh piece of pipe that im plugging up to and then may seal!
Old Oct 11, 2004 | 05:23 PM
vinnya77's Avatar
vinnya77
If you cut the inside one at the end and then just slide over the outer one when finished the fuel will travel back down the pipe in between the two. You will need to change that whole section, when you do you can then just use regular fuel line.
Old Oct 13, 2004 | 03:41 PM
LEECOS's Avatar
LEECOS
Default FUEL RAIL
I HAVE REMOVED MINE TO PREP FOR CONCOURSE LAST YEAR
I CUT THE INNER ONE OFF AND THEN CUT THE OUTER TO SAME SIZE ONCE THEY ARE SAME SIZE PUSH THE OUTER ONE BACK TO REVELE THE HARD INNER SLIDE THIS BACK ON TO THE RAIL AND MAKE SURE IT IS RIGHT ON IF IT IS RIGHT ON IT WILL NOT LEAK AND WILL LOOK FACTORY AGAIN
Old Oct 13, 2004 | 03:42 PM
LEECOS's Avatar
LEECOS
Default FUEL RAIL
muffster
13
Sep 3, 2015 09:40 PM
Bailes1992
Sep 3, 2015 02:17 PM
focrs
Sep 1, 2015 12:42 PM
Russ Hill
Aug 31, 2015 06:44 PM
mickparky81
Ford Focus ST
Aug 30, 2015 06:58 PM
