high comp turbo engines???????????????
how do the yanks run high comp zetec turbo engine (9.1) and get away with it and get big power out of them
but all the tuners here dont like high comp?????
They typically don't run much boost when on pump fuel so are no way near the power you often see quoted which is normally the fiqure for when running on 100+octane fuel.
Over here fuel at the pumps is in octane which is (ron+mon)/2. 100+ octane fuel is pretty potent as 93 octane fuel is about the same as 98ron super unleaded.
That is of course if your state is lucky enough to get 93 octane, the highest grade you can normally find in california is 91 octane which is the same as 95ron unleaded and 91 is the expensive stuff most cars are set up to run on cheaper 87 octane
. There is a simple reason fuel is cheap over here, its rubbish.
It's called a) low boost, big engines, b) low dynamic compression ratio due to silly cams and b) typically only used on the 1/4 drag strip where you don't get enough heat into the engine to drop pistons (unless it's really bad).
Physics is the same there as it is here, they arent doing anything that wouldnt work here too.
All down to what you want from it though, if its out and out power in a quick burst for the quarter then fair enough, if its being reliable in top gear when you plant it in the midrange up a big hill and hold it WOT with loads of ignition retard, then not so good.
You have to realise that the geometry (bore and stroke) of different engines means that some will take an increase in compression no problem and there will be good gains to have by this (Eg. Evos), where as others, all this causes is major heat related issues requiring severly retarded ignition (Cossies).
So saying high compression is good or bad is a misnomer, as it is TOTALLY reliant to it's particular engine configuration application.
We have an Evo 6 that we mapped that is running over 9:1 and it made 730bhp.
Between that and Gary's (715bhp @ around 8.5:1 I think), it looks like they are the 2 most powerful GT35 equipped Evo's in the UK.
Without checking, I don't know the bore and stroke of the Zetecs, so couldn't comment on whether these engines (like the Evos) lend themselves to high compression?
I have dealt with bike engines that can take a bar of boost with a static CR of nearly 11:1.
There are other factors that allow this eg cam timing but it does have a lot to do with their relativly small bore when compared to something like a cossie engine.
Its not just bore and stroke, its also a lot to do with rod angle, as this dictates the piston speed nearer to TDC where Det is most of an issue, for some reason though, that NEVER gets mentioned on PF
ekjim
Aug 17, 2015 08:57 PM
