MK4 Fiesta help please
Old Nov 14, 2007 | 02:52 PM
dinkydoo's Avatar
dinkydoo
Default MK4 Fiesta help please
Hi all,
First post so I apologise if this is in the wrong place!
I have a 1996 1.3 Fiesta Ghia that wont heat up inside.
The fans blow cold all the time, and also wont work on settings 1 and 2
Does anyone know if the heater pannel should have a cable attached to the back of each of the dial things on the circuit board? I have a cable on the heater setting dial, and one one the fan speed dial but nothing attached to the heat control dial.
I know the heater problem can be down to a problem at the matrix thing, but the heater panel has been removed and sprayed before I bought it, and the easy fix would be if something wasn't connected back up properly.
Thanks for looking
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Marv888
Sep 26, 2015 03:44 PM
