QUICK HELP PLEASE ..RE GRS
Old Oct 8, 2004 | 04:54 PM
Lee Reynolds's Avatar
Lee Reynolds
Default QUICK HELP PLEASE ..RE GRS
Got me new Bling cooler today ...Cheers Graham
I wanted to fit the slim kenlowe in between the rad and cooler, but to this and leave clearance for the fan 'nut', i will have to cut some of my bumper which ideally i dont wanna do. So, i decided to look at the way Kenlowe reccomend fitting it....intercooler butt up tight to the rad, then the fan to the cooler. Done this, but there is a little gap still in between the rad and cooler, about 5-8mm....this is becuse of the end being prouder than the cores.
IS THIS OK? Before i continue????
Lee..
Old Oct 8, 2004 | 04:59 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Yes, thats fine.
Make sure your rad is in good condition (preferably New) to prevent the cooling problems that you can easily get from completely covering the front of the rad!!
Old Oct 8, 2004 | 05:02 PM
Lee Reynolds
Cheers mate, yeah rad seems fine......going to flush it and refill with new coolant and fit an Rs cos thermostat. Ill keep my eye on it. If it gets hot ill have to buy a new rad and maybe a 2nd kenlowe.
Thanks C
Old Oct 8, 2004 | 05:52 PM
BODGE's Avatar
BODGE
lee i moved the rad back just a tad just at the bottom so as to upright it more, had some small brackets made up which had 2 holes in one to fix the bracket to the cross member and the other was a longer hole so the rad would slide back and forth to where i wanted
worked spot on and didn't need to move it back by much
mark
tankybaby66
Feb 6, 2016 02:24 PM
mk1turboestate
Dec 2, 2015 08:31 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
