Co adjustment help needed
Old Nov 14, 2007 | 05:19 AM
stevecossy's Avatar
stevecossy
Default Co adjustment help needed
I have a 91 saff 4x4 cossy red top, its running stage 3 on greens.
Had a prob which is now fixed but want to check/ adjust Co, im told differant things. Some say set it to 1-2% on idle others say between 3-5 so im not sure now and need some help.
Maybe i can see what shes at and then take readings over various rev positions to see if it goes weak or rich, worried if wrong i hole a piston if weak or bore wash on idle if rich. Cheers for any help. Steve
Old Nov 14, 2007 | 12:57 PM
iansoutham's Avatar
iansoutham
OCD Victim
Another option could be to go closed-loop. Much better, guaranteed pass on MOT for emissions (provided lambda sensor is functioning) and SO much better reponse and general driving.
Old Nov 14, 2007 | 04:42 PM
mechanic28's Avatar
mechanic28
stage 3 cossie as generally set between 2.5 too 4% depend on hoe the car runs but in general most are ok between2.5 to 3.56%
Old Nov 14, 2007 | 05:02 PM
stevecossy's Avatar
stevecossy
Ok cheers guys, had co checked today was 5.5% so ive adjusted it to about 2.5 ish. seems to go ok now.
Old Nov 14, 2007 | 07:14 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
more importantly you have now taken a percentage off your fuel map so check the fueling at peak boost or a meltdown could be on the cards
Old Nov 15, 2007 | 04:57 AM
stevecossy's Avatar
stevecossy
Ok cheers. When i raised the revs it went to 0.8% at 1st then as i raised revs more it seems to richen itself up. Suppose i should take it on the rollers 4 a proper set up.
Old Nov 15, 2007 | 02:56 PM
JTECH James
Passion for Fords!
or get a wideband on it you cant simulate boost fueling without making boost needs to be it done on the rollers or on road
Old Nov 16, 2007 | 10:14 AM
Yura's Avatar
Yura
what AFR is good at st3 at max boost, 12-12.5?
thanks!
Old Nov 16, 2007 | 01:47 PM
JTECH James
Passion for Fords!
ask whoever wrote the chip mate.....to risky to guess
jessie_rs
11
Jun 3, 2019 04:57 PM
kosienutter
31
Aug 22, 2015 09:55 AM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
dal3door
Aug 13, 2015 06:55 AM
col93saphcos
Aug 7, 2015 03:21 PM
