vibra-technics 2wd gearbox mount
does anyone have a vibra-technics gearbox mount fitted to there car?as i have just put 1 on my 2wd saff and when am going down the gears there is alot of vibration coming through the floor is this normal?if anyone has this on there car could help or had it would be great
__________________
__________________
yep, engine mounts only and std g/b mount
edit: ps, would it not have been slightly obvious that you would get some noise/vibration in the car?
the originals are made of rubber for just thos reasons, so when you remove the damping values of rubber and replace it with solid metal, you are going to get the issues that you have
standard one mate as its alot better going into gear and feels better to me after driving them back to back! just have to live wi it thanks for the help
i fitted very solid mounts to an XR2 years ago, was the same... very hard and noisey and did vibrate a lot - but fuck me it was tons better and responsive
I have a full set of vibratechnics waiting to go on mine now
TPM961
Jan 15, 2018 10:50 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
