temp guage won't move from the top??
my mate's just called me, and on his 2wd saff the temperature guage stays right at the top.... he's replaced the sender and had the clocks out.... then it's disconnected it goes down but as soon as you plug it in it shoots straight to the top
.... any ideas????
thanks....
.... any ideas????thanks....
Most likely an earth somewhere if not the actual wiring going to the sender check that as i had the same problem on my fiesta turbo and it turned out to be sensor wiring plug wasn't in good shap
hope that helps
hope that helps
Harryh24
Aug 26, 2015 07:50 PM
track.focus'd
Aug 12, 2015 05:53 PM
