Dump valve, is it right
Old Nov 13, 2007 | 03:57 AM
captiva's Avatar
captiva
Default Dump valve, is it right
Just bought a Group A dump valve for my stage 3 Cossie 4x4 and works well but when the engine is idling I can hear air (vacuum) being sucked in through the vent holes in the valve. Is this right?
Old Nov 13, 2007 | 04:26 AM
stevecossy's Avatar
stevecossy
I have a collins dump valve on my 4x4 and it is slightly open on idle and when ya rev it then it closes allowing boost to build up. Hope this helps mate.
Old Nov 13, 2007 | 04:34 AM
captiva's Avatar
captiva
Sounds right then if yours is doing it like mine. You would think it would make the AFR wrong and get an erratic idle. I have got that but it was there before I fitted the dump valve.
Old Nov 13, 2007 | 04:50 AM
stevecossy's Avatar
stevecossy
My idle is ok, fitted 1 of these to my mates rs focus and that realy not like it so we went back to the std.
Have you a grp A cone on yours too ? I have k+n and that and dump valve sound great,loud intake sucking noise followed by turbo chatter and dump valve whoosh when come off gas. Smiles 4 miles.
Old Nov 13, 2007 | 05:15 AM
captiva's Avatar
captiva
My idle is alright untill you switch off the engine when hot and start it again and the idle revs to 2000 and the only way to stop it is to disconnect the ISCV and reconnect it. Have done all the checks, cleaned the ISCV, checked for air leaks, set the baseline idle whatever. When I put another chip in ECU it cures it, go figure.
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
