spigot bearing and rear oil seal removal (cos)
Old Oct 8, 2004 | 02:13 PM
B11GNS's Avatar
B11GNS
Default spigot bearing and rear oil seal removal (cos)
as title.
Have removed box, clutch and flywheel and i'm going to replace the above items, anyone know how to remove them?
Old Oct 8, 2004 | 03:37 PM
B11GNS's Avatar
B11GNS
bttt
Old Oct 8, 2004 | 04:32 PM
B11GNS's Avatar
B11GNS
Come on peeps, someone must know
Old Oct 8, 2004 | 04:40 PM
Default Re: spigot bearing and rear oil seal removal (cos)
Originally Posted by B11GNS
as title.
You can get spigot bearing pullers. Your local engine reconditioner probably has one because they generally need to be taken out before a crank can be ground. If you can't borrow one then the easiest way is to get a length of steel bar turned down to an exact fit inside the bearing. 15mm from memory. Pack inside the bearing with grease until the whole recess is full and tap the bar in. Hydraulic pressure will force the bearing out from behind. The end cut off an old gearbox input shaft would do the trick.
To remove the seal drill a couple of 2mm holes in it and screw in some self tapping screws. You should be able to pull it out with molegrips.
Old Oct 8, 2004 | 04:59 PM
B11GNS's Avatar
B11GNS
Cheers, will give that a go. Might try to get a spigot tool, anyone know how much one might cost?
Danielbetty
Aug 28, 2015 08:01 PM
st220kyle
16
Aug 14, 2015 06:13 AM
Gadget
Aug 13, 2015 08:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
