my FRST i need some help please!!!!
Old Nov 12, 2007 | 08:49 PM
robertthorpe's Avatar
robertthorpe
Default my FRST i need some help please!!!!
I have just converted my XR2i into a fiesta turbo running a T3 and i have rebuilt the engine putting new gaskets on the head ect ect
i have got it started and running fine then suddenly after about 20 seconds it made a loud whistling noise which slowly got louder coming from the head which sounds like a air leak,
i had a listen and i couldnt locat were it was coming from, i then started to check every thing was attached e,g the brake pipe, idle valve pipe, inlet pipes, boost hoses ect ect thinking not much of it once it was warm i tryed to give it a rev,
it wouldnt rev properly and when i put my foot down it just trys to cut out
and wont properly rev or come on boost and when it dose rev
(which is done by very slowly putting your foot down) it gets to about 4500 and stops and starts to cut out, it also wont idle properly
i have changed the wiring it need e,g has frst map sensor and ECU
any ideas would be much appreciated and could help greatly
Old Nov 12, 2007 | 08:53 PM
rst in breaking's Avatar
rst in breaking
have you modded the loom to work so it recognises boost? i know there is 2 wires i think that need swapping for this
Old Nov 12, 2007 | 09:38 PM
robertthorpe
yer the amal valve it has been bypassed and will have a bleed valve there, this car before i owned it had a frst engine in it and that run fine so what could have changed
Old Nov 13, 2007 | 06:14 AM
Eagle's Avatar
Eagle
Super Moderator
sounds like an air leak somewhere ...
Old Nov 13, 2007 | 01:15 PM
paceo's Avatar
paceo
are you running a D/V? if you are not, make sure the little pipe where the D/V would connect to on the inlet is blocked off - i had this problem when i took my D/V off.
Old Nov 13, 2007 | 02:26 PM
Neil@FastFord's Avatar
Neil@FastFord
Check the gasket you used on the inlet mate
I changed some gaskets a while back. I just rushed through it and could hear a massive air leak, turned out to be the wrong gasket in the kit!!
Went back to BMS to get a single one, gave them all the info etc and they still came back with the wrong gasket!
Old Nov 13, 2007 | 05:13 PM
robertthorpe
when ifitted it it all seem ed correct, it looks like iam going to have to take the whole inlret off again was hoping it might have just been a simple pipe!!! the bit were the dump valve gose i have already got blocked atm
Old Nov 13, 2007 | 09:34 PM
robertthorpe
have just stripped down the inlet manifold and cleaned it up and put it back on, seems sorted no more whistle but it is has now come to my knowlage that it is over fueling MASSIVELY and the large amout of fuel is blowing out the spark!, i am going to have a fiddle try some diffrent ECU's and stuff and see how it gose tommorow at least that bloody whistling noise has gone and its revving (even if it dose us a 5ers worth in one rev lol
Old Nov 14, 2007 | 12:50 PM
Neil@FastFord
Good news! I'd be wary just throwing ECU's on personally
what management?
Chip?
Injectors?
Old Nov 15, 2007 | 10:41 PM
robertthorpe
i have just tryed a OFAC ecu and it is running better! but still like a bag of shit and been taking it out for a drive and it only takes bout quatar throtle and then starts jumping and dying, it is also still using too much fuel! iam going to change the throttle position sensor tommorow but it worked fine before i changed the engine so i dont think its that, but its somthing to tick off the list
1) EFI
2)no chip
3) Standard injectors (blue)
Old Nov 16, 2007 | 01:53 PM
paceo's Avatar
paceo
1) EFI
2)no chip
mate seriously, you need to get the car on a rolling road and set up correctly, remember if you dont know what your doing leave it alone, at the end of the day you dont want your engine blowing up if its too lean/rich.
i had the jumping and dying problems on my old red fiesta rs turbo as it was over fuelling massivly and once set up it was running great.
Old Nov 16, 2007 | 08:23 PM
robertthorpe
yer thats what i was thinking but i dont want to take a day off work spend money on petrol ect ect if there is somthing wrong with it or they wont run it! on the contarary dose any body know a good rolling road near Bromley, Croydon area!
where do did you get yours set up (if you have) peaco as i notice you live in west wickham
and you say you nhad jumping dying problems could i ask for some more of your syptoms please so i could see if it the same kind of thing
Old Nov 17, 2007 | 09:08 AM
paceo's Avatar
paceo
the nearest rolling road i believe is torque of the devil in uxbridge around the m25. if the car is not set up properly the engine will eventually fail
yeah the main problem was from cold, you revved the car and it would die, then wouldnt start and smelt badly of petrol. take the spark plug out and tell me what colout it is - black = running rich, white= running lean. should be a chocolate brown colour.
yeah i see you live in biggin hill, i have worked in biggin hill for 4 years
dont suppose you have a spare cvh sump do you?
Old Nov 17, 2007 | 06:22 PM
robertthorpe
errr yes actually i do have one off of my old 2i block in ok condition if ya want it were bouts do you work
i cheked the spark plugs the otha day they are black so i belive it is running to rich and maybe trying to boost to high and ECU i cutting it out any i dea how much they cost to set it up at TOD
Old Nov 17, 2007 | 07:56 PM
robertthorpe
power engineering is in uxbridge aswell isnt it
Old Nov 20, 2007 | 07:09 PM
paceo's Avatar
paceo
power engineering is mate, but i have heard raving reviews about tod, how much do you want for the sump? but whats the condition first ? i dont want a battered one! i work at royal mail, so tell me where you are and ill have a look. pm me address if you want.
Old Nov 20, 2007 | 09:13 PM
robertthorpe
just had a look and the block has gone (damb pikeys!) but i can get you one in good condition from a freind will pm you once i have it off and checked it over you know ben everrett who drives the clio
Billy_RS
16
Oct 11, 2025 09:41 PM
gambo08
Sep 16, 2015 08:10 PM
bigryrs
Sep 5, 2015 02:57 PM
rsturbo27
Sep 1, 2015 09:54 PM
bigryrs
Aug 28, 2015 05:32 PM
