Quick question on electronics!
Old Nov 12, 2007 | 05:01 PM
RichieST's Avatar
RichieST
Default Quick question on electronics!
Hi guys and girls
Here's one for you,
How long will a 12v 21watt bulb take to fully discharge a 3000mah 7.2v battery pack?
Thanks in advance
Rich
Old Nov 12, 2007 | 05:11 PM
Moonie's Avatar
Moonie
Dont think this is correct but...
W/V=A
so
21W/7.2V = 2.9A
3000mah = 3Ah
So i would say around an hour but the doesnt sound right somehow
Old Nov 12, 2007 | 05:22 PM
RichieST's Avatar
RichieST
ok mate cheers for that, well its currently on, so i'll let you know in an hour
Old Nov 12, 2007 | 05:23 PM
Oddified's Avatar
Oddified
About 1 3/4 hrs.
The 12v/21w bulb doesn't take 21w when it's powered with 7v2
Old Nov 12, 2007 | 06:08 PM
RichieST's Avatar
RichieST
been on for about 45 mins now and the bulb is dying!!! Battery pack wasn't fully charged tho, so i reckon maybe between the two times is about right!
Old Nov 12, 2007 | 06:12 PM
Moonie's Avatar
Moonie
I took into account the battery pack not being fully charged so i win
Old Nov 12, 2007 | 06:13 PM
Nick.'s Avatar
Nick.
Don't use a bulb to discharge Rc car battery packs.. does them no good
Old Nov 12, 2007 | 06:53 PM
RichieST's Avatar
RichieST
ok mr know-it-all, what should i use?
Old Nov 12, 2007 | 06:55 PM
Nick.'s Avatar
Nick.
Spintec battery manager
http://cgi.ebay.co.uk/SPINTEC-Batter...QQcmdZViewItem
Old Nov 12, 2007 | 06:58 PM
AlexF's Avatar
AlexF
go on then
back up that theory
Old Nov 12, 2007 | 07:10 PM
RichieST's Avatar
RichieST
so i have to spend Ł50 in order to do the same job as a 29p bulb and a bit of wire?
If you have the knowledge to back up why I should do so, then please do tell
Old Nov 12, 2007 | 07:11 PM
Nick.'s Avatar
Nick.
When discharging the pack.. bringing the down to 1.1v-0.8v per cell is fine..
But below that voltage cells in the pack start to become unbalanced and some will discharge lower than others, when the cells start to drop below the reccomended 1.1v-0.8v discharge limit they start to produce gas which starts to build up pressure inside the cell which makes the cell/cells start to vent which loses water and damages the cell/cells permantly.
Which is why you buy a propper piece of discharging piece of equipment like the spintec which not only discharges the pack down to a safe voltage (will cutoff if it senses anything wrong) but it also lowers the internal resistance, increase the voltage, increase runtime, increase capacity and increase the energy of the battery..
so no.. a bulb and a bit of wire won't do the same as Ł50 of propper equipment.. so if you do use the spintec you might make your Rc project go fast..
But to be honest id just go Lipo
I thank you.
Old Nov 12, 2007 | 07:18 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
well and truely answered!!
I thank you.
Old Nov 12, 2007 | 07:44 PM
RichieST's Avatar
RichieST
http://cgi.ebay.co.uk/LRP-NiMH-NiCd-...QQcmdZViewItem
so would this one be just as good at 1/5th of the price??
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
