HELP PLEASE.... *PIC*
Old Oct 8, 2004 | 12:59 PM
Paddy's Avatar
Paddy
Legend
Default HELP PLEASE.... *PIC*
Just fitted the oil breather to my S2 - it's exactly the same one as in the picture below.
All the pipes are sorted EXCEPT for the left hand elbow on the throttle body [ringed in the pic], where the fook is it sposed to go to?
It normally goes to the small breather that attaches to the underside of the crank case emmissions valve?
Old Oct 8, 2004 | 01:18 PM
Lemon S2's Avatar
Lemon S2
My one goes to my boost gauge. but other than that not sure what goes there
Old Oct 8, 2004 | 01:20 PM
Paddy's Avatar
Paddy
Legend
Cheers for trying Lemons mate, thats the elbow on the right that go's to the ECU and the boost gauge?
Can someone with an oil breather check where there left go's PLEASE
Old Oct 8, 2004 | 01:23 PM
EssexBoyRacer's Avatar
EssexBoyRacer
i think u either use it for auxillary stuff like boost gauges etc.. or just block it off.
Paul Eggleton's Avatar
Paul Eggleton
Do not connect to the breather at all!. Block it off or use it for a boost or act gauge. I had mine connected to my breather until Karl pointed out that you are actually pressurising the breather system with boost if you connect it up Not good. One single pipe with no 't-off' should go to the ECU, the other to boost or act gauge.
Paul.
Old Oct 8, 2004 | 01:25 PM
Lemon S2's Avatar
Lemon S2
I've got the oil breather on mine as well. Before I fitted the breather I used to have a 3way plug in the hose where one went to the ecu one went to the boost gauge & the other went to the elbow on the throttle body. I then fitted the breather & put the boost gauge on the left elbow instead.
HTH.
Old Oct 8, 2004 | 01:28 PM
TILLIO's Avatar
TILLIO
paddy, unscrew the elbow, and put a bolt in it
Old Oct 8, 2004 | 01:36 PM
Paddy's Avatar
Paddy
Legend
GUYS THANKS VERY MUCH for your help I've got a boost gauge currently on t-piece on the right hand elbow, so I'll swap it onto the left instead
Old Oct 8, 2004 | 03:45 PM
ballin's Avatar
ballin
you can fit mine now Paddy!!!!
Old Oct 8, 2004 | 04:02 PM
Steven_RW's Avatar
Steven_RW
u can connect it to the breather system with the one way std valve.
RW
Old Oct 8, 2004 | 04:09 PM
Paddy's Avatar
Paddy
Legend
Yeah no worries mate, so long as you got a pot of coffee on the go
Did you get the fitting kit with it too mate?
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
griffo69
Oct 4, 2015 11:58 AM
locum8
Oct 1, 2015 01:50 PM
