FAO Stu etc URGENT please
Old Oct 8, 2004 | 12:48 PM
ImaRacing 700's Avatar
ImaRacing 700
Default FAO Stu etc URGENT please
Can anyone tell me the number on the ecu plug that supplies each of the extra 4 injectors?
Obviously i know this but i need to corespond each one to that pin...otherwise i got to re install.
So
pin ?? no 5 inj
pin ?? no 6 inj
pin ?? no 7 inj
pin ?? no 8 inj
The SECS ecu is different!
Old Oct 8, 2004 | 12:49 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
PHONE HIM and if you get Kenny, he will ALSO know .
Old Oct 8, 2004 | 12:51 PM
ImaRacing 700
I can call many people Mike..BUT i am trying to save on phone call cost ROFL
Old Oct 8, 2004 | 12:54 PM
Mike Rainbird
Caraholic
Twat .
Old Oct 8, 2004 | 01:03 PM
Jim Galbally's Avatar
Jim Galbally
i didnt know the super8 stuff had 4 extra injector drivers?
i thuoght they all had a common pin?
Old Oct 8, 2004 | 01:14 PM
foreigneRS's Avatar
foreigneRS
Testing the future
L8
cyl 1, pin 35
cyl 2, pin 32
3, 33
4, 18
all have a common positive and switched earth.
Old Oct 8, 2004 | 01:15 PM
Jim Galbally
do cossie ECUs have 4 inj drivers as standard then?
Old Oct 8, 2004 | 01:24 PM
foreigneRS's Avatar
foreigneRS
Testing the future
not necessarily because it's batch injected, not sequential
Old Oct 8, 2004 | 01:27 PM
Jim Galbally
so as standard they dont have 4 inj drivers?
but the super8 adds another 4?
or are the pins internally connected to the same circuit?
i just assumed batch injecttion... 2 inj drivers, 2 pins hence adding another 4 injectors would add another 2 inj drivers/pins
as oposed to on my car where i have 2 injector drivers ie 2 pins for switched earths, and these are joined togther in banks of 3 in the wiring loom
i'm just trying to learn, not pickin holes or anything
ImaRacing 700
Cheers German bloke
Old Oct 8, 2004 | 01:35 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i didn't say they don't have 4 injector drivers jim, but i didn't say they did either.
if it's batch injection, why would you need 2 drivers for 2 injectors? what's wrong with having one driver for all 4 (or 6 for that matter) injectors? or even one driver per injector but all fired at the same time? the possibilities are endless.
Old Oct 8, 2004 | 01:37 PM
foreigneRS's Avatar
foreigneRS
Testing the future
if you want to learn, read this jim
http://www.sonic.net/~mikebr/efi/ecu_hdwr.html
Old Oct 8, 2004 | 01:38 PM
ImaRacing 700
Foreign....those are the first 4 injectors!!!
the sub loom uses pin 2,6,9,22...but which is what injector i DONT want to tahe the loom out!
Old Oct 8, 2004 | 01:42 PM
foreigneRS's Avatar
foreigneRS
Testing the future
sorry phil and jim - i didn't read the crucial 'extra injectors' bit
Old Oct 8, 2004 | 01:47 PM
Jim Galbally
shouldnt take more than 5 minutes to buzz em out with a multimeter phil
Old Oct 8, 2004 | 01:48 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i don't quite understand the question now - must be cos i'm foreign.
what does it matter which pin is what injector - it's batch injected (that means they all fire at the same time so they don't have to be connected in any particular order)
Old Oct 8, 2004 | 01:49 PM
Jim Galbally
FRS, surely theyre fired in 2 banks tho? ie 1 on 1 off?
ps S8 can use fully sequential injection, so getting the right pins is of some inportance
Old Oct 8, 2004 | 01:54 PM
ImaRacing 700
Jim..can you explain how i do that please?
Old Oct 8, 2004 | 02:01 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you think you've got time at full boost at over 7000 rpm to be able to fire in 2 banks? depends on your injector flow rate of course, but i don't think you have on 'std' yellows or greens.
why piss about with setting up sequential injection? not really much to be gained imo, and certainly getting the best out of it would be very difficult for a diy tuner without the use of an engine dyno.
Old Oct 8, 2004 | 02:07 PM
Jim Galbally
phil, get multimeter place 1 terminal in the multiplug and poke the other in the ECU connector holes until you find the ones that match... then note down which ones do which
if you got a shitty multimeter, use the resistance function to fine out which is which... if you got a good multimeter, set it to continuity test (shit multimeters dont do continuity)
Old Oct 8, 2004 | 02:12 PM
ImaRacing 700
Cheers Jim....always forget how to use the multimeter ....Kenny at MSD is getting the info though...so saves me the hassle of doin that!!!!
Old Oct 8, 2004 | 02:17 PM
wes's Avatar
wes
This is how mine is wired:
22 = injector 5 (cyl 1)
09 = injector 6 (cyl 2)
02 = injector 7 (cyl 3)
06 = injector 8 (cyl 4)
This is on a L8 based super8, i believe the P8 uses a different pin for injector 7 (pin 02 is used for the lambda sensor on the P8), i don't know what pin the P8 uses for this injector.
Old Oct 8, 2004 | 02:21 PM
ImaRacing 700
Thanks WES
