Removing studs from the front hubs, just smack them?
Old Nov 12, 2007 | 03:56 PM
rog's Avatar
rog
Default Removing studs from the front hubs, just smack them?
As title, just ordered hubcentric spacers and new longer stus, now to remove the old ones i simply.......?
From looking at them can i just smack them out from the front or are they threaded in??? Reason i ask such a simple question is that I am in this predicament becuse of a recent balls up with a std set of brakes which has now meant i need to fit my other bigger set and i don't want anything else going wrong just yet....
Old Nov 12, 2007 | 03:58 PM
lardypants's Avatar
lardypants
yep smack em out
Old Nov 12, 2007 | 03:59 PM
rog's Avatar
rog
Cheers, i thought as much, just wanted to check before something else went t1ts up...
silky16v's Avatar
silky16v
Get on That!
fit an old wheel nut first, just screw it down as far as it will go with out showing the head off the stud and then give it a good wack with a hammer the stud should then come loose from the back of the hub
Steve Escos
Ford Focus ST Parts for Sale
Oct 19, 2015 05:34 PM
Aug 29, 2015 08:16 PM
C2 MAK
Aug 20, 2015 09:46 PM
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
