T38 UT or Harvey Gibbs (SCS)
I;m with Pete, i have the Universal myself, all i can say is it comes in around 3700rpm and pulls all the way to the limiter, they do there job..
Think they're around 1200 quid aren't they?
The UT version was developed by Harvey on his dyno whilst Vince was still working there. Harvey experimented with loads of different variations by swapping the compressor and turbine wheels around, before settling on the one that worked best on the engine dyno.
Accordingly, as far as I am aware, the UT version SHOULD be the same as the HG version (unless Vince didn't divulge the exact specs before he left to go to CR Engineering).
However, despite the machined housings, it still isn't perfect, as they don't make big torque figures like the T34s. Fortunately he is now experimenting with a purpose built high flow roller bearing turbo that should do everything that the T38 did PLUS make big mid-range torque.
Originally Posted by montecos400
What about the CR turbos T38 roller bearing.
Anyone with experience of this. What are the advantages over the normal T38's
The new one that I keep harping on about won't be tested until end of this week / beginning of next.
Danielbetty
Oct 3, 2015 06:01 PM
timsrs
22
Sep 24, 2015 08:14 PM
Disabled Account
Jun 6, 2005 09:39 PM
