Xenons, Bi Xenons?? what are the differences please?
xenons are single filament (effectively) for cars with seperate main beam bulbs
bi-xenons, either have 2 bulbs, or are motorised, and are suitbale for cars which use the same bulb for both dipped and main beams (RST's cossies etc)
hope this helps
hope this helps
hope this helps
hope this helps
hope this helps
hope this helps
in most cheap HID kits. the bi-xenon is acheived by a solenoid pulling the bulb backwards (the shiled stays in the same place) to put the bright bit in the same place as it would be with a dual filament bulb so that the reflector works in the same way
wowk
Mar 30, 2021 07:49 PM
SMILER258
Sep 28, 2015 09:04 AM
