MSD Cloosed Loop Chip - Help!
Old Nov 7, 2007 | 09:50 PM
Thanasis's Avatar
Thanasis
Default MSD Cloosed Loop Chip - Help!
Hi,i have in my 2wd cossie the msd cloosed loop chip,but i have a problem,i have adjustment the CO just the MSD instructions but in the end of exhaust it removes smoke and it smells petrol intensely,what can i do? what is to blaim? it should go to CO machine for correct regulation? what must be check? maybe sensors?
**My cosworth is 2wd but with L8 ecu,and i have changes the wires of TPS,also i have replaced the 2wd TPS(PF01) with 4x4 TPS(PF09),my indle valve works fine!!
any help appreciated
thanks a lot.
Thanasis
Old Nov 7, 2007 | 10:04 PM
mechanic28's Avatar
mechanic28
what did u set the co to at idle?
Old Nov 7, 2007 | 10:26 PM
Thanasis's Avatar
Thanasis
5 turns clockwise and then 1.5 turns anti clockwise
Old Nov 8, 2007 | 07:08 AM
Yura's Avatar
Yura
no, what CO in % at idle?
and did you have lamda sensor connected to ecu for cloosed loop working?
Old Nov 8, 2007 | 08:22 PM
Thanasis's Avatar
Thanasis
yes offcource i do that
Old Nov 12, 2007 | 11:20 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
should be around 0.90% at idle
make sure all base settings are correct, ie fuel pressure etc etc, and make 100% sure you have NO air leaks.
Old Nov 12, 2007 | 05:20 PM
cossie604's Avatar
cossie604
Why ask here? Why not ask MSD, they are very helpfull and offer good customer aftersales advice.
Old Nov 12, 2007 | 07:30 PM
KSA-Cossie's Avatar
KSA-Cossie
As above after sales are excellent.
tankybaby66
Feb 6, 2016 02:24 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
RSmark84
Sep 13, 2015 01:29 PM
