FAO Cristian APT - ebay error
You have made an error in your ebay listing which i think you should inform your bidders of.
How can these injectors be a "drop in upgrade" for a cossie when they are high impedance and cossies run low impedance injectors?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MESE:IT&ih=006
Originally Posted by Garage19
Well you learn something new every day!
Will it not effect the opening speeds?
offset minimum opening time.
Besides, those "modern" injectors open nearly as fast as low impedance type anyway.
Can you access/change the injector opening time figures in a weber ecu?
Unfortunately, only the "chosen few" can do it properly.
It is one of the most basic requirements to change ANY map.....yes you can
I don't mean the injector opening time eg 30 ms of fuel x load and x rpm i meant the actual allowance for opening the ECU makes for the time the injector spends actually opening - something like 0.8 - 1.5 ms if i remember correctly (Simon??).
remind me what impedance is please?
ages since I done any lekky stuff
Originally Posted by ©hatter Box
how much oms runs though the wireing irrc
