What type of clutches for over 500bhp 2wd and 4wd?
My mate just finished his engine with T4 Bd15 eccc and used an AP 6 paddle clutch but it seems that is not up to the job so I wondered what U guys use for this kind of power? Thanks
Yeah sure, The thing is that the pressure plate was not AP I think! It was another ripoff from some guy but we fitted a helix pressure plate with the ap 6 paddle and seems that is fine for now, we see tomorrow on the drag strip. thanks for the help mate.
Personally I would go twin plate with a hydrualic conversion.... Speak to Reyland Motorsport, they will sort you out, did me a good deal. I will only be running 400ish BHP but want reliability and a lightish clutch
yeah that will be the most best thing to do. Another mate of mine is running a Mc leod twin plate 7.25" sintered clutch on 4wd esc 550bhp and he says that the gears go easy as you got everything standard. Now we can prepare a flywheel to get ready for the sintered clutch and a single plate conversion will be enough for the 2wd! But for now will keep running with the 6 paddle as today it went ok!
Do you really feel a speed difference in gearing when using a twin plates clutch over a single plate or is it just £££ ? I don't think we need the lastest tenth of a seconds, but I wanted to know if it is really shortening the gear changes.
dojj
28
Sep 11, 2015 10:00 PM
