Cosworth engine oil - where do i get it from??!!
I know this has been talked about alot but i just want to check....
my car is 2wd running about 335 bhp, and is using Silkolene Pro S 10w50 Esther Synthetic.... is that the right stuff i should be using????
thanks.
thanks.
Originally Posted by BA
the main reason i ask is that i have been told that i shouldnt use fully synthetic, which this oil is.... do you have any comments on that??
the cossies came from the factory running 5w30 fully synthetic.i have always run mine on this from ford.or an equivalent if i needed to and i was not near ford.
ive always been supplied the 5w30 by ford themselves. 148k later its still fine
ben as lon as the grade is the same and its a synthetic it will mix fine mate
big_Rad
Sep 15, 2017 09:36 AM
JoeyBoyden
Aug 18, 2015 10:52 PM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
