hydraulic handbrake help!!!!
Old Nov 3, 2007 | 05:19 PM
rst-g's Avatar
rst-g
ZETEC TURBO
Default hydraulic handbrake help!!!!
got a s2 turbo and want rid of the abs and want hydraulic handbrake how do you plum it in with the Bias valve anyone know? diagram
Old Nov 3, 2007 | 06:48 PM
SafeChav's Avatar
SafeChav
Just a thought - Aren't hydraulic handbrakes an MOT failure
Old Nov 3, 2007 | 07:28 PM
rst-g's Avatar
rst-g
ZETEC TURBO
yes av got to make a bracket so it can be locked in place
Old Nov 3, 2007 | 08:30 PM
Aaroncast's Avatar
Aaroncast
hydr- h/brake ------
firstly why??????
so lets procceed---------lol
your hanbrake needs to be cable for mot-no exceptions sorry--------
and old trick on early rally cars was to drill through the pads and put a metal pin in so you moved the pads and not the caliper ()both sides!!!)-lol
hydro!/h/brake-----
basically brakes need spliTting front and back-twin system yeah!!-?
that sorted you need the pipes in the car up to a brake cylinder and your handbrake adapting for a push rod so when you list the handbarke you pressurise the system into the system needs to go the bias valve OR as i preffer! A BALANCE BAR!!!--- go to burtons power products and you will find everything you need and diagrams etc -ALSO ARE YOU THINKING FLY OFF!!!!!!!!------BIT MEAN FOR A ROAD CAR !!!! HOPE YOU KNOW HOW YOUR USING IT!! BIT LIKE LEFT FOOT BRAKING GET IT WRONG AND WHOW!!!!
Old Nov 4, 2007 | 05:15 PM
Wardy257's Avatar
Wardy257
No. Your handbrake must be on an independant system from your foot brake. It does not have to have a cable although most do.
You could do this but it would be a lot of hassle for a road car.
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
hopper350
Sep 4, 2015 12:53 AM
