fiesta turbo plumping
Old Nov 2, 2007 | 06:35 PM
scottrennie14's Avatar
scottrennie14
Default fiesta turbo plumping
i was wanting to plumb my turbo oil return to a cooler and then instead of having the return going to the sump, i was thinking of putting it in to the head as on extra lube for the rockers etc, was wondering if this would cause a problem for the turbo as the oil would have to push it self up hill to the head rather than just draining into the sump!!!!
also what is the best jic sized hose to use for the oil return
any help will be great as im not the good at the old turbo side of things
Old Nov 2, 2007 | 07:07 PM
paceo's Avatar
paceo
Default Re: fiesta turbo plumping
would never work.
this is mine-
Old Nov 3, 2007 | 07:10 AM
scottrennie14
thanks but can u explain why it wouldnt work
Old Nov 6, 2007 | 02:22 PM
ram's Avatar
ram
Has a large member
wouldnt have thought it would work mate seeing as the oil would have to drain upwards. nice idea though
Old Nov 6, 2007 | 03:58 PM
Luca's Avatar
Luca
Lukesville
it has to drain mate so must fall to its location...
same way your plumbing in tour house works any waste falls through the waste pipes etc
it would need to be powered to move upwards.
Old Nov 8, 2007 | 07:32 PM
scottrennie14
they way i was thinking, if its going into the turbo at 50 psi then it should come out of the turbo at some sort of pressure so would force itself up hill
thanks anyway for all the advice keep it coming
Old Nov 8, 2007 | 09:02 PM
Chris69's Avatar
Chris69
interesting idea i think there might be too much oil in the head then though- surely it would effect the engines breathing is wot i mean
Old Nov 10, 2007 | 06:58 AM
scottrennie14
i was thinkin that myself, but i was thinking more like there might be to much oil in the turbo housing and the turbo might burn oil!!!!!!
Old Nov 22, 2007 | 04:32 PM
mike2530's Avatar
mike2530
Extra oil in the head wouldn't have any benefit as the oil wouldn't be in the sump where the oil pick-up is where it is essential. No point oil sitting in the head when the sump is empty and you engine is sucking fresh air causing big damage to your crank, bearings and any other oil critical parts.
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
turbobill
Aug 1, 2015 08:55 PM
