small oil burning issue with my fiesta rs turbo - advice ;-)
Old Nov 2, 2007 | 06:27 PM
paceo's Avatar
paceo
Default small oil burning issue with my fiesta rs turbo - advice ;-)
im having a small issue with my fiesta rs turbo burning a small amount of oil. i have recently had my oil return plumbed into the sump as the standard oil return is rubbish. here is what i have replaced to try and solve this matter-
oil return now into the sump for better drainage (this is originally what i thought was causing it with the standard t2 return)
new standard breather
cleaned all existing breather hoses
had a step-gap seal put into the turbo (for exhaust)
replaced stem seals with genuine ford items
dry compression test @ 170psi over all 4 cylinders
i get a oil smell when i come to a stand still from driving, with a tiny tiny amount of smoke. when on idle i rev the car up and see some smoke but does not smell oily for some reason? more of fumes. the car has been off the road for a while now so im hoping it may need a good long drive.
please advise me on what else i may need to check - my car is on 47k, all standard engine wise and im the 3rd owner.
Old Nov 4, 2007 | 12:23 AM
dannyblackpool's Avatar
dannyblackpool
Boost Builder
check for play in shaft, is there any forward and back?????
is the feed got a restrictor??
t2 units are a waste of time mate tbh, i dont sell em now as they just smoke lol
Old Nov 4, 2007 | 02:13 AM
paceo's Avatar
paceo
im thinking it might be below oil level whats causing it. turbo has been checked and ive have a stepp gap seal put in it.
Old Nov 5, 2007 | 12:40 PM
paceo's Avatar
paceo
here is where mine sits - ive put a red circle where i will have the new one put, it will be definatly above oil level and out the way of the oil pickup bracket behind the sump. it will also clear the alternator.
big_Rad
Sep 15, 2017 09:36 AM
carlo
24
Oct 5, 2015 08:20 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
knight19770
Aug 4, 2015 12:36 PM
