hd enough rebuild due
Old Nov 2, 2007 | 03:28 PM
ladsarmy's Avatar
ladsarmy
Default hd enough rebuild due
i have a standard series 2 escort 1990 i want to go FASTER i have 1500 to spend i also have just purchased a t3 hybrid roller bearing turbo stage 3 anyone any ideas what would be good and reliable
Old Nov 2, 2007 | 03:36 PM
SafeChav's Avatar
SafeChav
Whats done to it now?
With your £1500 you want to look at the following areas
Front mount IC
Performance exhaust system
Turbo (which you already have)
Chip
A set up with a reputable tuner (often overlooked after fitting upgrades)
You may also be able to afford some head work or buy an uprated head.
Old Nov 2, 2007 | 03:37 PM
ladsarmy's Avatar
ladsarmy
Default eng
have a stainless exh looking at a stage 3 head just now what sort of chip cheers
Old Nov 2, 2007 | 03:43 PM
SafeChav's Avatar
SafeChav
Well the chips on these cars don't really do a fantastic amount because its only on the ignition side of things so there isn't a great deal of difference. however if i were to recommend anyone to you to get a chip from it would have to be either Stu @ MSD or Christian @ APT (both traders on here)
A stage 3 head isn't really going to see you any benefits unless you're going to be running high boost levels and really have a turbo worthy of it.
A front mount really is your next best step and is probably some of the best money you could ever spend.
Old Nov 2, 2007 | 03:45 PM
ladsarmy's Avatar
ladsarmy
Default eng
ok thanks mate cheers what about a 2.0 zetec turbo there one for sale could i just drop that in get it remapped at a place like ava in glasgow
Old Nov 2, 2007 | 03:47 PM
SafeChav's Avatar
SafeChav
i like your "drop it in" thoughts
Has it crossed your mind what management you would run a zetec turbo off??
Old Nov 2, 2007 | 04:15 PM
ladsarmy's Avatar
ladsarmy
Default eng
a was going to leave that up the mapper mate ava in glasgow mate what sort of managment is best
Old Nov 2, 2007 | 04:20 PM
SafeChav's Avatar
SafeChav
well yea but what i mean is.......if you buy a zetec turbo you can't run that off the the MFI you have now.
You would need EFI and unless it comes with everything its going to get expensive!
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
mjonathan24
Oct 29, 2015 10:39 PM
Mc5506
Oct 5, 2015 09:57 PM
